| mod utk l2 std pekak..? apa resipi korg...? | |
+11ahmad Albab witch12 marchcup MAKitam kai_ree fakhrul skronotoros hantukubur matnoor red_k madi 15 posters |
madi Active in DRAG
Number of posts : 253 Birthday : 30/12/1984 Age : 39 Location : selayang Registration date : 24/02/2010
| Subject: mod utk l2 std pekak..? apa resipi korg...? Wed 26 Jan - 2:31 | |
| salam otai2 semua...
di dalam kbosanan yg melanda diriku ini... aku just nk mencari info mod utk 660T std pekak...nk buat jalan2 pegi pasar...
soalan aku mudah ja...
utk setup 660t std, top mount, semua std cuma ada metal gasket ja:
1. tebo apakah yg sesuai dipakai..? memandangkan tebo standard senang kong.. owner xmo keta lag, nnti bini marah kata kete abg kemutt...
2. org kata tebo standard senang kong... max boost utk tebo standard supaya dia xkong...?
3. klu ada resipi utk setup 660t std ni.. boleh la kongsi2 sempena qong xi fa cai nk menjelang tiba ni... tarian singa amat dialu-alukan...
jawapan otai2 n member2 forum semua amat lah dihargai...
sekian, newbie...
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Wed 26 Jan - 11:20 | |
| tdo4, fuel reg , boost 1.5 ada bajet afc 5 but..... dah ok ...bawak jalan2 haha | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 27 Jan - 15:45 | |
| tebo standed ikt pglman keta aku..biar bg standed boost..0.5bar mcm tu..huhu..lembab tul..Tp kalo tdo409 mmg best lah dgn 1.2bar above..
org kata kalo fr ni biar yg ori pnya..kat mn ada jual yg ori pnya ah? hehe curi line skt.. | |
hantukubur
Number of posts : 8 Registration date : 26/01/2011
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 27 Jan - 16:06 | |
| Mau bagi pandangan sket... kalau aku masuk RHF4 VF20, fuel regulator 48psi, boost controller. Ok dah tu... blh dah jln2 pi pasar | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 27 Jan - 19:09 | |
| mcm kenal avatar hantukubur ni... huhu | |
madi Active in DRAG
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Fri 28 Jan - 1:29 | |
| hantukubur: v20 xlag ker....? safc? fuel pump? injector..? sory la ekk byk tnya..
lain2 pendapat...? | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Fri 28 Jan - 11:28 | |
| nk sesedap boosting mcm ayam ckp 2 la.. td04-09, fuel regulator, injektor 240cc, safc 5button, fuel pump evo.. aku smpai skg pkai spec cmni.. sedaaaaaaaappppppp..kekekekke.. | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Sat 29 Jan - 12:33 | |
| - skronotoros wrote:
- nk sesedap boosting mcm ayam ckp 2 la..
td04-09, fuel regulator, injektor 240cc, safc 5button, fuel pump evo.. aku smpai skg pkai spec cmni.. sedaaaaaaaappppppp..kekekekke.. leh caya ke..?hehe.. tp spec seperti diatas mmg best la, yg ni btul aku yg pakai,tp boost 0.6 je la.. | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Sun 30 Jan - 5:16 | |
td04-09, fuel regulator, injektor 240cc, safc 5button, fuel pump evo.. aku smpai skg pkai spec cmni.. sedaaaaaaaappppppp..kekekekke.. leh caya ke..?hehe.. tp spec seperti diatas mmg best la, yg ni btul aku yg pakai,tp boost 0.6 je la.. same la spec... yg x same injectore stendet... SAFC 1... | |
madi Active in DRAG
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Mon 31 Jan - 2:24 | |
| toros: spec ko nya tipu...piston besau..tebo kecik...cam buka byk... valve spring dah mod... aku pun rasa mcm tu juga... apa pendapat korng tentang rhf4-v13..? ada sapa2 penah pakai..? | |
MAKitam Moderator
Number of posts : 474 Location : melaka Registration date : 24/02/2010
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Mon 31 Jan - 6:01 | |
| - madi wrote:
- toros: spec ko nya tipu...piston besau..tebo kecik...cam buka byk... valve spring dah mod...
aku pun rasa mcm tu juga... apa pendapat korng tentang rhf4-v13..? ada sapa2 penah pakai..? aku x pena pkai la tp dah dkt 8 bijik aku dah jualkan siap mod bontot stded....so far xde masalah.... | |
marchcup Active in DRAG
Number of posts : 99 Location : k.trg Registration date : 25/02/2010
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Tue 1 Feb - 3:05 | |
| kasi std je madi..
spec idamanku : enjin l2s @ l5 @ 850 std, power steering, auto...layannnnn | |
witch12
Number of posts : 20 Registration date : 24/02/2010
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Wed 23 Feb - 6:59 | |
| turbo standard pun best per..
spec dlu..
paip ekjoz 2inci dr depan.. fuel reg.. metal gasket.. afc 5 button.. boost 1.2bar.. melompat2 dia pergi hahaha bole la main2 ngan 1.6
aku pakai turbo neh 3 tahun boost neh ok je.. nasib kot.. den tukar tdo4 plak | |
ahmad Albab Active in DRAG
Number of posts : 66 Location : Sabahan Registration date : 09/05/2010
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 24 Feb - 2:03 | |
| paling senang REMAP ECU,buang boost cut,fuel cut sama speed cut,syok...aku main ni jak...boost pun senang2 jak up ke 15psi@1 bar...takde masalah... | |
sebut_Syukri
Number of posts : 14 Registration date : 07/04/2011
| Subject: boost Mon 11 Apr - 14:45 | |
| boost camne korg setting? anta kdai ke ape..sory sye noob giler | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Tue 12 Apr - 15:47 | |
| - madi wrote:
- salam otai2 semua...
sekian, newbie...
tu diaaa.. posting paling kon3k sekali dalam cmcommy... apasai aku baru perasan hari ni... hahahahhhahahah | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Tue 12 Apr - 17:03 | |
| - sebut_Syukri wrote:
- boost camne korg setting? anta kdai ke ape..sory sye noob giler
hantar pi pomen ler ,,,psg tulang ikan ,,n set ler boost secukup rasa ... | |
madi Active in DRAG
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 14 Apr - 6:27 | |
| jepp: hhahahah..mcm haram hg jepp... | |
madi Active in DRAG
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 14 Apr - 6:33 | |
| - marchcup wrote:
- kasi std je madi..
spec idamanku : enjin l2s @ l5 @ 850 std, power steering, auto...layannnnn tu yg semolek2nya...ni nk bg sedap p keja ni... | |
panjang Active in DRAG
Number of posts : 206 Registration date : 27/02/2010
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 14 Apr - 8:05 | |
| madi, hang pi wat ekzos straight...........pastu masukkan safc blue kalo nak sedap tak pun 5 button....tune dyno..........ini setup aku pakai nak sapu piala kat drag UIA dulu.........ternyata berkesan....ekekekkekekek............dan boleh bwk jalan2...... | |
kereta_buruk Active in DRAG
Number of posts : 130 Birthday : 10/02/1985 Age : 39 Location : puncak perdano Registration date : 26/12/2010
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? Thu 14 Apr - 8:28 | |
| ade cadangan nk dyno kt mane??? xpernh dyno lg ni... selalu dyno brpe ek kena byr?? sungguh xtau sungguh ni... huhuhuhuhuhu | |
| Subject: Re: mod utk l2 std pekak..? apa resipi korg...? | |
