April 2024
Tuning EF-RL 1000T Icon_minitimeSat 5 May - 6:19 by red_k
Tuning EF-RL 1000T Icon_minitimeTue 14 Jul - 16:14 by caroulx
Tuning EF-RL 1000T Icon_minitimeTue 14 Jul - 16:11 by caroulx
Tuning EF-RL 1000T Icon_minitimeThu 2 Oct - 4:18 by Edzuan
Tuning EF-RL 1000T Icon_minitimeMon 22 Sep - 1:49 by kancil 4543
Tuning EF-RL 1000T Icon_minitimeFri 12 Sep - 3:46 by zakiemlk
Tuning EF-RL 1000T Icon_minitimeThu 14 Aug - 16:29 by ferulnbm
Tuning EF-RL 1000T Icon_minitimeThu 14 Aug - 6:48 by genji kuwahara
Tuning EF-RL 1000T Icon_minitimeThu 10 Jul - 16:44 by mesin tebu
 Tuning EF-RL 1000T
2bMIRA
mamat999
garret10
8 posters
garret10
Number of posts : 46
Registration date : 30/07/2010
Tuning EF-RL 1000T Empty
PostSubject: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSun 8 May - 4:26
all delete
garret10
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSun 8 May - 5:40
starter is weak?if i wrong
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSun 8 May - 14:48
ermm nih perlu bantuan dari pakar2 nih ,,,
http://www.keicar4life.blogspot.com
mamat999
mamat999
Number of posts : 192
Birthday : 22/07/1984
Registration date : 19/04/2010
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSun 8 May - 14:59
try check compression
2bMIRA
2bMIRA
Number of posts : 8
Registration date : 08/02/2011
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSun 8 May - 15:34
Very Happy takut aku tengok isi perut kreta mu...betui tu...cek kompresion...
kreta aku pg ni tak bleh stat langsung...tekan minyak....tak hidup...last2 bunyi "blob" kat piston....meibe gasket putus, head problem, piston bocor....esok bru tahu...hu..hu...
silver_grashopper
silver_grashopper
Birthday : 13/07/1985
Registration date : 03/03/2010
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeMon 9 May - 0:23
cek cmpresion.....
KM RACER-X
Super Dragger
Super Dragger
KM RACER-X
Number of posts : 551
Birthday : 08/07/1982
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeMon 9 May - 3:34
tukar fuel pump tu n injector... minyak x naik... fuel pump ada bunyi x masa on kunci?...
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeMon 9 May - 8:11
aku penah ade kes cmni gak..
ssh btol nk start..sejuk ke panas ke suam ke sume same..
then, aku tmbah grounding + pasang relay kt starter..
alhamdulillah smpai skg xde masalah.. Cool
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeMon 9 May - 16:01
alternator kong kot.cuba ground satu cable connect dri starter ke alternator.....
http://www.smokerhaven77.com
garret10
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeMon 9 May - 16:08
1)tadi aku dah check the compression tester at 14psi...high pressure dah...how many the low compression suitable for turbo or 2.0bar??
2)susah nak start engine sbb high compression....aku dah cuba guna bateri NS70,then start engine dah ok...tpi engine masih x smooth lgi..buat adj fuel regulator at 50-55psi...smooth sikit
lgi,minyak tak cukup...need upgrade to injector besar lah....
3)cuba add gasket 2mm atau 2.5mm sbb aku mau 2.0bar je...tpi rhf4 tak blh boost tinggi sbb sng kong...baik tukar turbo lain hehe td04-09 blh tahan apabila mau boost tinggi klu aku silap??
garret10
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeMon 9 May - 16:15
alternator n starter takada masalah lgi......susah nk start engine sbb high compression at 14psi hehe....buka head lgi....tambah gasket...
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeWed 11 May - 6:40
ok.so dh settle masalah?congrates! cheers
garret10
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSat 28 May - 13:09
blm settle lgi...dh psg gasket 2mm dan injector vr4 450cc,then try full throttle at 63xx rpm tpi tak blh high rpm...apa masalah??mesti guna s-afc??
garret10
PostSubject: Re: Tuning EF-RL 1000T   Tuning EF-RL 1000T Icon_minitimeSat 4 Jun - 4:55
bro upgraded to injector vr4 + safc 5 button...skrg dh settle mslh.tq for reply....
Tuning EF-RL 1000T
» emanage tuning ...
» Wideband Tuning Services
» SDB Round 2, Cat. Kcar <1000t RESULT
