| Tuning EF-RL 1000T | |
+42bMIRA mamat999 red_k garret10 8 posters |
garret10
Number of posts : 46 Registration date : 30/07/2010
| Subject: Tuning EF-RL 1000T Sun 8 May - 4:26 | |
garret10
| Subject: Re: Tuning EF-RL 1000T Sun 8 May - 5:40 | |
| starter is weak?if i wrong | |
| Subject: Re: Tuning EF-RL 1000T Sun 8 May - 14:48 | |
| ermm nih perlu bantuan dari pakar2 nih ,,, | |
mamat999 Dragger
Number of posts : 192 Birthday : 22/07/1984 Age : 39 Location : terengganu Registration date : 19/04/2010
| Subject: Re: Tuning EF-RL 1000T Sun 8 May - 14:59 | |
2bMIRA
Number of posts : 8 Location : pahang Registration date : 08/02/2011
| Subject: Re: Tuning EF-RL 1000T Sun 8 May - 15:34 | |
| - mamat999 wrote:
- try check compression
takut aku tengok isi perut kreta mu...betui tu...cek kompresion... kreta aku pg ni tak bleh stat langsung...tekan minyak....tak hidup...last2 bunyi "blob" kat piston....meibe gasket putus, head problem, piston bocor....esok bru tahu...hu..hu... | |
silver_grashopper Active in DRAG
Number of posts : 71 Birthday : 13/07/1985 Age : 38 Location : seremban Registration date : 03/03/2010
| Subject: Re: Tuning EF-RL 1000T Mon 9 May - 0:23 | |
kreta aku pg ni tak bleh stat langsung...tekan minyak....tak hidup...last2 bunyi "blob" kat piston....meibe gasket putus, head problem, piston bocor....esok bru tahu...hu..hu... cek cmpresion..... | |
KM RACER-X Super Dragger
Number of posts : 551 Birthday : 08/07/1982 Age : 41 Location : Seremban - Senawang Registration date : 24/02/2010
| Subject: Re: Tuning EF-RL 1000T Mon 9 May - 3:34 | |
| tukar fuel pump tu n injector... minyak x naik... fuel pump ada bunyi x masa on kunci?... | |
| Subject: Re: Tuning EF-RL 1000T Mon 9 May - 8:11 | |
| aku penah ade kes cmni gak.. ssh btol nk start..sejuk ke panas ke suam ke sume same.. then, aku tmbah grounding + pasang relay kt starter.. alhamdulillah smpai skg xde masalah.. | |
| Subject: Re: Tuning EF-RL 1000T Mon 9 May - 16:01 | |
| alternator kong kot.cuba ground satu cable connect dri starter ke alternator..... | |
garret10
| Subject: Re: Tuning EF-RL 1000T Mon 9 May - 16:08 | |
| 1)tadi aku dah check the compression tester at 14psi...high pressure dah...how many the low compression suitable for turbo or 2.0bar??
2)susah nak start engine sbb high compression....aku dah cuba guna bateri NS70,then start engine dah ok...tpi engine masih x smooth lgi..buat adj fuel regulator at 50-55psi...smooth sikit lgi,minyak tak cukup...need upgrade to injector besar lah....
3)cuba add gasket 2mm atau 2.5mm sbb aku mau 2.0bar je...tpi rhf4 tak blh boost tinggi sbb sng kong...baik tukar turbo lain hehe td04-09 blh tahan apabila mau boost tinggi klu aku silap?? | |
garret10
| Subject: Re: Tuning EF-RL 1000T Mon 9 May - 16:15 | |
| - awent77 wrote:
- alternator kong kot.cuba ground satu cable connect dri starter ke alternator.....
alternator n starter takada masalah lgi......susah nk start engine sbb high compression at 14psi hehe....buka head lgi....tambah gasket... | |
| Subject: Re: Tuning EF-RL 1000T Wed 11 May - 6:40 | |
| ok.so dh settle masalah?congrates! | |
garret10
| Subject: Re: Tuning EF-RL 1000T Sat 28 May - 13:09 | |
| - awent77 wrote:
- ok.so dh settle masalah?congrates!
blm settle lgi...dh psg gasket 2mm dan injector vr4 450cc,then try full throttle at 63xx rpm tpi tak blh high rpm...apa masalah??mesti guna s-afc?? | |
garret10
| Subject: Re: Tuning EF-RL 1000T Sat 4 Jun - 4:55 | |
| bro upgraded to injector vr4 + safc 5 button...skrg dh settle mslh.tq for reply.... | |
| Subject: Re: Tuning EF-RL 1000T | |
