 Nak Tanya Spec enjin
subaruimpreza81
Number of posts : 49
Birthday : 10/08/1981
Registration date : 23/06/2011
PostSubject: Nak Tanya Spec enjin   Sat 25 Jun - 16:54
salam semua...
teman nak tanya skit r...
sesape ada full spec enjin untuk Kelisa 850cc?
kot la ada workshop manual enjin tu ke
@ sesapa blh bgi spec piston, bore x stroke n etc. untuk enjin kelisa 850cc ni...
harap saudara kt sini blh tolong.
View user profile http://subaruimpreza81.blogspot.com/
sipanitera
Number of posts : 80
PostSubject: Re: Nak Tanya Spec enjin   Mon 27 Jun - 8:23
rasa mcm xramai yg mod enjin nie.pyh pulak nk tau specnyer.xpe tunggu geng2 lain jawab
subaruimpreza81
PostSubject: Re: Nak Tanya Spec enjin   Mon 27 Jun - 12:30
harap2 ada la yg tahu....
PostSubject: Re: Nak Tanya Spec enjin   Mon 27 Jun - 18:40
aku rasa keluaran kancil 850 dohc efi lebih kurang sm dgn kelisa 850..ni spec kancil DOHC efi 850cc
2002 PERODUA KANCIL 850 EZi
Capacity : 847cc
Bore and stroke : 66.6/81.0 mm
Compression ratio : 10:1
Cylinders : 3, in-line
Valve arrangement : DOHC, 4 valves per cylinder
Cylinder head : Light alloy
Cylinder block : Cast iron
Fuel feed : EFI
Max. power (DIN) : 36.7 kW/5200 rpm 50 bhp/5200 rpm
Max. torque : 74.4 Nm/4000 rpm
Catalytic converter : Yes
subaruimpreza81
PostSubject: Re: Nak Tanya Spec enjin   Tue 28 Jun - 0:32
Capacity : 847cc
Fuel feed : EFI
tq bro. piston ape yg sesuai untuk kemaskan lagi enjin NA ini?
PostSubject: Re: Nak Tanya Spec enjin   Tue 28 Jun - 4:42
utk enjin kelisa 850cc aku pn kurang pasti bro..
tp dlu mbr aku wat kancil 850cc..
die masuk pisten l2s tebo (high comp) ngan head 12valve..
subaruimpreza81
PostSubject: Re: Nak Tanya Spec enjin   Tue 28 Jun - 5:02
piston l2 hcomp mn blh dpt?
PostSubject: Re: Nak Tanya Spec enjin   Tue 28 Jun - 11:28
yg pasti ....blok 850 twin cam nih ....sleeve lebar dari 850 yg biase tuh ,,so kalo nak bikin tebo leh sumbat piston 2e ,,,,,if 850 biase takleh masuk piston 2e ...
subaruimpreza81
PostSubject: Re: Nak Tanya Spec enjin   Tue 28 Jun - 12:26
tapi bro...... NA is BETTER...hehehheheee..ape yg sesuai
subaruimpreza81
PostSubject: Re: Nak Tanya Spec enjin   Wed 29 Jun - 3:25
lagi 1...tbody ape yg ngam n besar skit kt enjin tu?
PostSubject: Re: Nak Tanya Spec enjin   Thu 30 Jun - 2:17
aku ade 1set.. Basketball
subaruimpreza81
PostSubject: Re: Nak Tanya Spec enjin   Thu 30 Jun - 4:27
kasi pic n rege skit
PostSubject: Re: Nak Tanya Spec enjin   Fri 1 Jul - 2:24
agak2 kalo masuk piston 2e na ...buat engine na bleh tak ? hehe aku pon tak sure hehe ..
COMPACTMOTORSPORTS :: Friends of Compactmotorsports :: Normally Aspirated-
