May 2018
 t.body, intake manifold
cross
Number of posts : 28
Birthday : 31/10/1986
Registration date : 26/03/2011
PostSubject: t.body, intake manifold   Fri 7 Oct - 2:58
bro2 sekalian..sy ingin menimba ilmu sal t.body/intake manifold custom..byk yg sy nmpk kedua2 bnda ni org wat custom..utk 660t,jenis custom camner yg sesuai?dr segi ukuran plak?respon?
PostSubject: Re: t.body, intake manifold   Sat 8 Oct - 2:19
aku pakai velocity punya ok jek ...item made from alloy ..
refer >>> http://keicar4life.blogspot.com/p/my-keicar-drag-project-car.html
cross
PostSubject: Re: t.body, intake manifold   Sat 8 Oct - 4:46
saiz mmg perlu lbih bsr utk yg custom ni?npa xda yg mod stock bg bsr?
qayyumhasan
Number of posts : 4
Birthday : 01/01/1991
Registration date : 22/10/2011
PostSubject: Re: t.body, intake manifold   Sat 22 Oct - 4:20
ak pun pkai yg velocity..t.body s90 evo..boost jd cpt msuk..best2..
cross
PostSubject: Re: t.body, intake manifold   Sun 23 Oct - 13:00
t.body tu apa jenis yg paling baik utk dguna?
PostSubject: Re: t.body, intake manifold   Mon 24 Oct - 6:03
paling besar kalo pasang kat std ,,,,TB 4E ....pakai charade 1.3 pon ok gak ...leh jek
cross
PostSubject: Re: t.body, intake manifold   Mon 24 Oct - 6:54
klu spec smua da bsr,gna tb yg lbih bsr mcm gsr tu ok tak?yg bsr tu tmsuk ler piston,injektor,pump,tebo..spec skg ni mc gak 660 cume da msuk piston 72mm,dll smua da tkr..yg mc standet cume intake & tb
PostSubject: Re: t.body, intake manifold   Tue 25 Oct - 3:31
try la masuk 4e or 4age ....besar sgt pon tak best lak .... aku dulu pakai 1.3 charade ...ade geng pakai 4e n 4age pon sdap gak ..gsr kalo kalo ko nak try apa salahnya hehe ,,, tak cuba tak tau ,,
cross
PostSubject: Re: t.body, intake manifold   Wed 26 Oct - 13:33
aku mmg ada fkr2 nak try tb gsr,tp intake tu custom sndiri..da ada sape2 ka yg gna tb gsr ni kat 660t?
PostSubject: Re: t.body, intake manifold   Mon 31 Oct - 6:57
ermm kalo pakai kat intake std ,,,,aku pakai sr20 punya ,,,,aku pakai kat 660t aku ..
witch12
Number of posts : 20
PostSubject: Re: t.body, intake manifold   Mon 31 Oct - 7:31
secara kasar nya.. kalau pengunaan custome intake berapa hp naik kalau pakai intake standard dengan tb besar berapa bole naik.. kalau2 bole sifu2 bole kasi anggaran kasi?
let say pada block 660t turbo besar
PostSubject: Re: t.body, intake manifold   Tue 1 Nov - 1:35
byk beza nya ,,,nak anggar hp naik bape pon susah gak nak kene tgk setup engine ,,,try pakai baru tahu best tak best ...kompom beza ..
cross
PostSubject: Re: t.body, intake manifold   Mon 7 Nov - 11:54
tb sr20 tu brpa mm??
mesin tebu
Number of posts : 9
Registration date : 27/06/2014
PostSubject: Re: t.body, intake manifold   Sat 28 Jun - 15:42
klu pakai tb dri kete lain soket tps tu kena pakai yg mana ek?pakai balik tps asal ke atau pakai tps yg dtg ngan tb tu?
PostSubject: Re: t.body, intake manifold   Sat 28 Jun - 15:58
Erm aku pakai tb sr20..tps pomen tak pakai..tak sambung wire kat tps pon ..
mesin tebu
Number of posts : 9
PostSubject: Re: t.body, intake manifold   Sat 28 Jun - 17:29
pki emanage xpe ke x pakai tps?prnah try skali cabut soket tps tu..idle jd gila skit..ecu xde prob ke klu x pki tps tu?
PostSubject: Re: t.body, intake manifold   Sat 28 Jun - 21:28
Aku pakai emanage lah... ade wayar yg oomen sambung bagi tps tu buka max....so far aku ok jek no prob... tapi kat eng L2 la..eng lain tak sure la..hehe
