January 2019
 Gearbox manual kelisa masuk kat kancil
garret10
Number of posts : 46
Registration date : 30/07/2010
PostSubject: Gearbox manual kelisa masuk kat kancil   Sat 25 Feb - 17:09
Salam,
Klu gb manual kelisa masuk kat kancil
1. Mounting -dpn blkg,pki yg asal balik,mounting gb tgk subframe klu std M'sia hole
screw yg xsama ngan subframe L2/L5s sama hole screw ngan kelisa....tgk mcm
ngam.....
2. Flywheel dan Clutch Plate -blh guna L2/L5s klu nk guna flywheel kelisa kena mod
sikit tp flywheel L2/L5 yg ringan drp kelisa klu x silap
4. Clutch Cable - kena pki kelisa klu nk guna kancil kena mod sikit tp susah sikit lgi
5. Padel Klac - blh guna kelisa/L5s yg sama klu nk guna kancil kena mod sikit klu
x silap
6. Speedometer Cable - blh guna kancil/L2/L5s
7. Gear Lever - Guna kelisa balik kena mod kena adjustable......
8. Starter - ori kelisa
3. Driveshaft - pki driveshaft apa?amcm?
garret10
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Sat 25 Feb - 17:14
sesiapa yg ada info psl driveshaft ni meh share kat sini....kiri kanan pki driveshaft apa?amcm?
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Sun 26 Feb - 8:51
Tak silap bende dah diss dulu....but takpelah tak salah kalo buat ulangkaji hehehe....nani aku try carik topic tuh paste sini...
Yg confirm driveshaft pakai kancil auto punya.....
garret10
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Sun 26 Feb - 9:58
ok sy dah cr xada mata dah penat hehehe....model mana punya?kancil 850 EZI auto if i x silap
zam1031
zam1031
Number of posts : 115
Birthday : 18/06/1971
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Sun 26 Feb - 10:22
yup...sesapa nak pakai gbox kelisa kat kancil....dshaft pakai kancil auto tahun 2002......terimakasih.... Laughing
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Sun 26 Feb - 11:44
Tq zam for the info....
garret10
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Sun 26 Feb - 12:48
Tq zam for the info......kdi spareparts ade jual nie?trus pnp ka?
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 3:37
Yup ade jual...pnp jek...
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 4:26
kalau guna cable clutch kelisa pakai kat padle clutch kancil cepat putus..
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 4:29
Tak silap aku punya pakai toyota ape tah....
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 4:32
guna lah cable clutch nisan sunny. mesti terbaik
ejat
Number of posts : 10
Registration date : 22/09/2011
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 7:15
driveshaft pakai kancil belalang 850 ezi auto injection..pnp je kiri kanan..
kabel clutch,klu pakai kabel clutch kelisa,kena pakai padel kelisa sekali baru ok..
klu pakai padel kancil,kne custom kabel clutch tu...
garret10
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 15:20
pki double cover jer....cable clutch nissan 130Y yg tahan?
garret10
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Mon 27 Feb - 15:25
sy pki padel L5 tp L5/kelisa yg same....sy pi beli kabel kelisa n 130Y dlu....
Registration date : 20/12/2010
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Wed 8 Aug - 18:03
kncil sy dh masuk gb kelisa manual ni.. masalahnya dlm 1 mgu msti kena ejas kabel klac 1-2 kali (utk klac pendek o panjang) sbb gear xmasuk wpun tekan abih pedal. pedal masa ni keras nak mampos. lps ejas klac panjang tekan lembut le skit tp tetap jg nak kena tekan abih pedal baru gear bole masuk..
pd mulanya sy pikir mgkin sbb ukuran kabel tu panjang n byk berlengkuk (so kabel tu xfree) jd sy tuko kabel baru kelisa n kustom skit utk kurangkan lengkok. ok skit tekan pedal agak lembut tp still nak kena ejas kabel (ejas klac pendek o panjang).. bila marking kat skru ejas (skru plastik) skru tu xlari. kenapa masalah ni terjadi? mgkin ke sbb 'penahan2' kabel tu membengkok menyebabkan 'setting' ejas klac tu lari?
ejat
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Thu 9 Aug - 2:18
gear level tu xngam sy rasa..kene adjust balik..
PostSubject: Re: Gearbox manual kelisa masuk kat kancil   Thu 9 Aug - 6:13
gear level mmg mcm loos skit.. dua galah bwh tu pun bengkok kan je..
COMPACTMOTORSPORTS :: Friends of Compactmotorsports :: Chassis/Wheel/Gearbox-
