i check the DAIHATSU GEARBOX GEAR RATIO
This is all the gear ratios from all std daihatsu gearbox's.With this you can make a close ratio box for any daihatsu.
GTti box
1st 3.090
2nd 1.750
3rd 1.23 or 1.25
4th 0.917
5th 0.750
final drive 4.643
CB-23,CB-61,CL-11,CL-61
1st 3.090 (34/11)
2nd 1.842 (35/19)
3rd 1.230 (32/26)
4th 0.846 (32/37)
5th 0.707 (29/41)
final drive
CB23 4.500 (72/160
CL11 4.933 (74/15)
CB61/CL61 4.642 (65/14)
Applause
1st 3.090 (34/11)
2nd 1.750 (35/20)
3rd 1.250 (35/2
4th 0.916 (33/36)
5th 0.750 (30/40)
final drive 4.266 (64/15)
Charade G200 1.3
1st 3.181
2nd 1.842
3rd 1.250
4th 0.864
5th 0.707
final drive 4.266
charade 1.5
1st 3.09
2nd 1.750
3rd 1.250
4th 0.864
5th 0.707
final drive 4.266
feroza
1st 3.752
2nd 2.182
3rd 1.428
4th 1.00
5th 0.665
if you use the gears out of a G202,G200 and a gtti box you can make a close ratio gear box using std parts.I guide around the corner from me works with daihatsu and has made 1 force his car and its unreal.Rospen also make the box.They use 1st,2nd and 5th from a G102 and GTti box and custom make 3rd and 4th from there group A rally gear sets.ratios are as followed.
1st 3.042
2nd 1.842
3rd 1.450
4th 1.180
5th 0.917
