April 2018
 TDO4 , RHF , GARRET ETC ..
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sun 21 Mar - 11:08
voicenoice wrote:
VF/VQ tu rasenye refer a/r (aspect ratio) housing turbin/compressor
contoh GARRET AR48/35 so Aspect ratio compressor=48 Turbin=35...
betol tak?
entah la....no komen....
limeston09
Number of posts : 136
Registration date : 18/03/2009
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sun 21 Mar - 17:27
betol tak?
newbie lg...xtau....heheheheh
Number of posts : 50
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Fri 9 Apr - 18:00
sy pkai td04-09 twinblade.. mmg sedap.. tp syg.. myk itam da menyembur keluar dr compressor..
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sat 10 Apr - 7:12
patut la ade perancangan nak pakai TD05H yek bro???
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sat 10 Apr - 7:42
ayarkk.. kantoi plak.. erkk.. cmne ley tawu??? musykil2... hmm...
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Wed 14 Apr - 11:13
ada mmber aku nk tolak ct12 kat aku, aku brangan nk angkat tggu hnjug bulan nnt huhu..apa pndpt korang?? sesuai kah utk aku yg masi internal stnded l2? tebo ni masuk rpm berapa?? pas beli tebo tu baru aku fkr nk tkr injector and bla bla.. Embarassed
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Wed 14 Apr - 19:49
matnoor: sy rasa la.. kene tukar internal parts gak...
1.piston besar
2.conrod bearing baik punyer
3.injector yg bersesuaian
4.unit kawalan bahan api
5.adjustable fuel regulator
6.fuel pump yg bersesuaian
7.hi-cam w/ campulley
8.metal head gasket 1.5mm 3ply
9.modified oil pump
10.lighten flywheel
11.lighten crankpulley
12.port polish intake n exhaust
13.big throttle body
14.intercooler yg bersesuaian
15.wastegate
16.custom banana extractor
17.piping i/c dan piping exhaust yg bersesuaian
ape lg? itu je yg sy rase bley bg 660T bwk ct12 dgn jayanye... Smile
just my 2cent. tp kalo bajet xdo.. pasang je turbo tu dlu.. turbo lambat spool = jimat minyak = duit banyak = beli brg banyak2...
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Thu 15 Apr - 2:02
bro ziq zana...byk nye nk modi utk 660t baru leh jd monster ek....baru laa sy tahu...poning ni.....
bro matnoor - TD04-09 pon dh ok.....
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Thu 15 Apr - 4:33
ct12 ye..agak besa tebo tuh..
utk internal stendet xleh nk bwk gak, lmbat spool..
aku cm bearz, suggest td04-09..internal stendet still leh bwk..
but at least, fuel system upgrade for safety reason and for upboost..
2je..
jz 2 share, dlu aku pkai 04-09 + 240cc injektor with internal stock..
boost daily 1.2 bar still xde masalah..
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Thu 15 Apr - 5:03
td04-09t.blade+piston 72+injector 275=boost 1.5daily driving...No problemo...
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Thu 15 Apr - 7:24
matnoor : ct12 tu besar sgt tu. kalau nak jugak guna keluaga CT ni. cuba guna ct9 utk internal stendert. aku ada ct9 kalau nak cuba test drive boleh lah datang selayang. kalau ngam berkenan buka lah harga aku jual ahahahhaha
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Thu 15 Apr - 13:37
aku mmg minat keluarga dari toyota, ct ni..huhu..tp, kalo dah jadi mcm ni nk ambk tdo4 o9 pun best hehe..tp, tu je lah mhl skg ni tdo4 o9..4rats ke ats kat sabah skg ni..
beehun
Number of posts : 44
Birthday : 13/01/1981
Registration date : 17/04/2010
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sat 17 Apr - 18:26
kalo pengguna enjin EFRL mcm sy ni tebo ape yg sesuai utk ugrade?..GARRET AR48/35 ok x?..
tp tebo stended L5 ni pun mcm lambat spool jek dgn enjin stended skang ni..huhu
akulanie
COMPACT Mechanic
Birthday : 07/08/1977
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sun 18 Apr - 6:02
- head std
- tb atoyot
- injector 2e
- ic arc topmount
- pistin 2e telu
- tebo ct12 weld trus kt header
- fuel pump da tuka
- boost 0.8
spec aku skang..so far so gud
syok gune ct12 nih sbb die punye bunyi wisel kt ejos..hehehe
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sun 18 Apr - 11:45
akulanie wrote:
- head std
- tb atoyot
- injector 2e
- ic arc topmount
- pistin 2e telu
- fuel pump da tuka
- boost 0.8
boost ko masuk time brapa rpm bro akulanie?? dulu ko smpat rasa x ct12 ni dgn pisten standed l2?? huhu Embarassed
akulanie
COMPACT Mechanic
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Sun 18 Apr - 20:05
[/quote]boost ko masuk time brapa rpm bro akulanie?? dulu ko smpat rasa x ct12 ni dgn pisten standed l2?? huhu Embarassed[/quote]
lbh kurg rpm 3k dah ade boost...tp kalo ikut lampu,boost 0.1 lbh bru die nyale...x smpt merase la mase pistin std dlu,rasenye lag byk gak kalo pistin std..
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Mon 19 Apr - 2:01
akulanie wrote:
- head std
- tb atoyot
- injector 2e
- ic arc topmount
- pistin 2e telu
- fuel pump da tuka
- boost 0.8
haha spec underdog ,,,ngan rim std ,,,bukak eng ..makaii ,,,macam2 ade .. hehe..
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Mon 19 Apr - 2:02
haha ... kenape lak tebo l5 tuh pon lambat spool ..patut ok jek ,,ade prob setting kot ,,
akulanie
COMPACT Mechanic
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Mon 19 Apr - 17:51
red_k wrote:
akulanie wrote:
- head std
- tb atoyot
- injector 2e
- ic arc topmount
- pistin 2e telu
- fuel pump da tuka
- boost 0.8
ala...syok2 je ayam oii...hehe
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Tue 20 Apr - 1:50
akulanie wrote:
red_k wrote:
akulanie wrote:
- head std
- tb atoyot
- injector 2e
- ic arc topmount
- pistin 2e telu
- fuel pump da tuka
- boost 0.8
syok ape kejadah nye kalo eng bay camtuh hehe ,, ..tunggu ko aku sampai g9 ,,aku paparazi kete ko tuh ,,, hehe
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Tue 20 Apr - 5:04
hahaha... best ni...
aku pakai turbo ikut pomen..
dulu pomen jepun bagi = aku rhb31
pastu pomen kulim = td04-09
pastu pomen puchong a.k.a janggut tabligh = td04L gsr
jadi?? pilihan aku? semestinya dari keluarga TD... aku dah di didik
untuk menjadi keluarga TD...
tp td04-09 on 660t pisten dara mmg mantap!!!!
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Tue 20 Apr - 5:09
hehe btul aku pon pernah merasa pengan td .. lain macam .. ehe
akulanie
COMPACT Mechanic
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Tue 20 Apr - 14:01
tidakk...aku benti keje ah...hehehe
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Tue 20 Apr - 15:34
orite...titk!!!...nk join fmily TD gak lah..hehehe..ngam feel ketika d jln,ble lah join tumpang sekaki dgn keluarga TD ni huhu...
PostSubject: Re: TDO4 , RHF , GARRET ETC ..   Wed 21 Apr - 2:01
try laa matnoor.. kalau ko pakai L2 pisten stended, cuba pakai td04-09 diesel twin blade... sebelum tu, make sure ko masuk dulu fuel pump besar (gsr,rb20,bosch,sr20 etc), then fuel regulator, injector besar 240cc ke atas, dan juga management (safc 5button, safc1, e-manage etc)..
sebabnye, td04-09 ni sedap kalau dapat range boost around 1.2-1.8bar.... tp kalau maximum 1.5bar pun dah totally porn!!
try laaa.. lagipun td04-09 ni skang macam dah murah... pergi laaa ajak kawan2 yg baik dgn tong turbo... situ ada jual td04-09 recond.. rege pun bleh citer... takde mahal pun...
tp modified keter jgn sampai lupa anak bini !! hahaha
Page 4 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
