| Managment setup | |
+13mirahaw chevalier.noir WakJoi black consonar ferulnbm zUrA^AniEySzA dvvt_T MAKitam red_k Bearz panjang 882T 17 posters |
882T Active in DRAG
Number of posts : 50 Birthday : 08/05/1983 Age : 40 Location : Puchong Registration date : 24/02/2010
| Subject: Managment setup Mon 15 Mar - 8:41 | |
| Memandangkan dah ramai geng2 Kcar yang pakai management kat kereta masing2, aku ader persoalan sama ada pernah tak sapa pernah cuba buat single coil utk setiap plug n tak pakai distributer. Makna nyer setiap plug akan ader single coil utk supply. Application nie utk yang pakai managment n pernah tak sapa2 pernah dengar n buat..? apa Pro and Cons..? Macam mana nak buat..? | |
panjang Active in DRAG
Number of posts : 206 Registration date : 27/02/2010
| Subject: Re: Managment setup Mon 15 Mar - 8:52 | |
| never done it before, sorry... | |
882T Active in DRAG
| Subject: Re: Managment setup Mon 15 Mar - 8:54 | |
| can be done right? just asking as there is a possibility on doing that... | |
| Subject: Re: Managment setup Mon 15 Mar - 8:55 | |
| ggod topic.....Malaysia boleh | |
882T Active in DRAG
| Subject: Re: Managment setup Mon 15 Mar - 9:06 | |
| setup nih selalu pakai kat kete besarkan ...example EVO .... ermm tak pernah tgk .. tapi aku rase l6 ke l5 mesti kene buat camnikan kalo nak api besar ...cam pernah dgr zam316 buat kat l5 dia ... tapi result tak tau lak ,, | |
882T Active in DRAG
| Subject: Re: Managment setup Mon 15 Mar - 9:10 | |
| betui tue ayam...biasa kereta besar buat benda nie.. utk L5 atau L6 atau mana engine COP takpe senang nak buat tapi utk engine 3 piston nie macam mana..?? sebab aku tau kena pakai barang kereta 6 piston utk distribute api mengunakan single coil...but distributer L2 tak support, betul ker..? kenapa..? RnD nie pernah tak discuba oleh geng2 K-car atau mana pomen utk engine L2? just nak tau outcome dan pro 'n' cons jea.... | |
| Subject: Re: Managment setup Mon 15 Mar - 9:33 | |
| haha yup2 dulu pi bangkok tgk geng besar bli coil MSD Twin Tower etc aku pon terfikir leh ke l2 buat .. tapi takpe aku nanti tanye ujang mane tau dia ade pikir ke buat ..ape prob kalo nak buat hehe .. - 882T wrote:
- betui tue ayam...biasa kereta besar buat benda nie..
MAKitam Moderator
Number of posts : 474 Location : melaka Registration date : 24/02/2010
| Subject: Re: Managment setup Mon 15 Mar - 9:47 | |
| lain managment aku x tahu tp eM ultimate bole buat...nak tarik 1 plug 1 coil...injector individu pun bole....tp aku x buat lg psl xde modal nak pkai eM ultimate lg....tp kena amik brang dr keta besar pnya...
tu yg tengah nak kaji ade sape2 yg dah masuk eM ultimate ni..... | |
| Subject: Re: Managment setup Mon 15 Mar - 9:50 | |
| haha nice info ... | |
dvvt_T Active in Circuit Racing
Number of posts : 114 Registration date : 24/02/2010
| Subject: Re: Managment setup Tue 16 Mar - 17:34 | |
| kalo yang l5.... kalo die pakai wiring n head jbdet mmg pakai individual coil....
same mcm efrl jugak...
betul ke???
kalo kat l2, memadai ke pakai MSD botol susu tu??? | |
MAKitam Moderator
| Subject: Re: Managment setup Tue 16 Mar - 22:37 | |
| Subject: Re: Managment setup Wed 17 Mar - 1:47 | |
| ermm utk l2 660t ..aku tgk CAU tuh pakai coil std jek ,, power jek tgk hehe ... - dvvt_T wrote:
- kalo yang l5.... kalo die pakai wiring n head jbdet mmg pakai individual coil....
betul ke???
zUrA^AniEySzA Active in DRAG
Number of posts : 281 Birthday : 07/10/1985 Age : 38 Location : sErEmbAn-sEri kEmbAngAn-sErEmbAn Registration date : 24/02/2010
| Subject: Re: Managment setup Wed 17 Mar - 5:31 | |
| - MAKitam wrote:
- ya....nice info...
NicE InfO.... | |
MAKitam Moderator
ferulnbm Moderator
Number of posts : 394 Birthday : 14/11/1983 Age : 40 Location : rawang,n9 Registration date : 23/02/2010
| Subject: Re: Managment setup Wed 17 Mar - 8:11 | |
| topic terhangat d pasaran
nice info | |
| Subject: Re: Managment setup Wed 17 Mar - 9:31 | |
| Subject: Re: Managment setup Wed 17 Mar - 10:10 | |
| alahh, dulu aku dah buat dahh... tp tak jadi sebab MSD coil aku kena sita dgn TNB sebab tak bayar bil letrik... so, aku abaikan aje laa... | |
| Subject: Re: Managment setup Wed 17 Mar - 10:21 | |
| ooo... mcm xde efek ke pakai msd coil tu???
abam pornostar, thermal wrap ade lg??? | |
black Moderator
Number of posts : 470 Birthday : 16/07/1971 Age : 52 Location : Alor Setar,Kedah Registration date : 24/02/2010
| Subject: Re: Managment setup Wed 17 Mar - 11:11 | |
MAKitam Moderator
| Subject: Re: Managment setup Wed 17 Mar - 13:45 | |
| - consonar wrote:
- alahh, dulu aku dah buat dahh...
tu dia otai msd dah start turun ilmu..... | |
| Subject: Re: Managment setup Wed 17 Mar - 15:18 | |
WakJoi Active in DRAG
Number of posts : 15 Birthday : 22/03/1977 Age : 47 Location : pandan indak,k.l Registration date : 07/03/2010
| Subject: Re: Managment setup Wed 17 Mar - 16:27 | |
| maaf mencelah.. mngikut pengalaman sy main standalone ecu ni kalo nk jlnkn 1 coil stiap silinder ni kna tetap ada distributor atau crank angle sensor. (enjin yg pakai crank sensor ni tak de distributor..). kalo signal takde maka berterabur la plug bgi api,memang tak idup la enjin. distributor atau crank sensor akn bgi signal bila masa nk bgi api utk setiap silinder. utk standalone ecu yg ada ignition output je (microtech 'S' series,haltech,motec, dll...) yg bole guna direct coil. kalo enjin L2 pakai microtech lt10s dh senang2 je pakai 3 coil luar tpi distributor masih kna pakai sbb utk bgi signal. ( maaf kalo kenyataan sy ni tak berapa tepat.. tpi rasa2 tepat ni ) rasa2 kalo pakai direct coil ni lagi sempurna sbb tak akn terjadi miss firing... mana taknye.. dh la 1 coil je nk bgi api kt distributor.. pastu distributor pulak nk kna agih2kn api ke setiap silinder..pastu nk lalu kt plug cable pulak... kan lambat tu.... | |
MAKitam Moderator
| Subject: Re: Managment setup Wed 17 Mar - 23:25 | |
| thanks 4 d'infomation wakjoi....btol jgk.... | |
| Subject: Re: Managment setup | |
| Managment setup | |
