April 2024 | Mon | Tue | Wed | Thu | Fri | Sat | Sun |
1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | | | | | | Calendar |
| | camne nak kira compression ratio ,,,, | |
| | Author | Message |
| Subject: camne nak kira compression ratio ,,,, Wed 7 Apr - 19:10 | |
| meh diss camne nak kira ,,, | |
| | | red_k Admin
| Subject: Re: camne nak kira compression ratio ,,,, Wed 7 Apr - 19:11 | |
| | | ZiQ nANa
Number of posts : 50 Registration date : 02/03/2010
| Subject: Re: camne nak kira compression ratio ,,,, Sat 10 Apr - 6:54 | |
| boleyh kot bro... hehe.. yg sy tawu laa... 1. sekeping kaca yg lutsinar (ada 1 lubang kt kaca tu tuk isi air) 2. picagari(yg doctor pakai tuk inject org tu..) 3. liquid yg berwarna(bkn warna air kosong) 4. cylinder head 5. piston(kalo enjin anda piston low compression) cara2: kaca tu letak atas cylinder head, den isikan liquid ke dlm picagari, suntikkan liquid tu ke dlm kaca yg berlubang tu.. pasti kan amek bacaan kt picagari tu.. isi sampai penuh... catatkn bacaan brape ml digunakan tuk memenuhi combustion chamber.. ulang prosedur di atas untuk piston pula.. lepas nih ada kiraan.. aku lupe cm ner nak kira... spe2 yg tawu cmne nk kira sila la sambung.. jgn mara.. hehe... | |
| | | dvvt_T Active in Circuit Racing
Number of posts : 114 Registration date : 24/02/2010
| Subject: Re: camne nak kira compression ratio ,,,, Sat 10 Apr - 21:05 | |
| dah kire isi padu yang tu.... kire je isipadu BDC to TDC pakai rumus 3.141 x (jejari)(jejari) x stroke = ???? pastu bahagi jawapan kat atas ni ngan isipadu combustion chamber yang kire sebelum ni td.... dapat la comp ratio...... dalam perumpamaannye.... kalo comp ratio 10:1 macam 10 helai kertas di compress menjadi tebal sehelai kertas..... kalo salah tlg jolokkan.... | |
| Subject: Re: camne nak kira compression ratio ,,,, Sat 10 Apr - 21:08 | |
| | | red_k Admin
| Subject: Re: camne nak kira compression ratio ,,,, Sun 11 Apr - 3:56 | |
| ..bagus2 ,,, aku info link nih kat ujang ..dia yg suh cari byk formula utk kira ,,, comp ratio ..leh banding ngan formula2 lain ,, | |
| | | ZiQ nANa
| Subject: Re: camne nak kira compression ratio ,,,, Sun 11 Apr - 5:04 | |
| | | Sponsored content
| Subject: Re: camne nak kira compression ratio ,,,, | |
Similar topics | |
| Permissions in this forum: | You cannot reply to topics in this forum
