April 2024
Setting Timing,Idle Icon_minitimeSat 5 May - 6:19 by red_k
Setting Timing,Idle Icon_minitimeTue 14 Jul - 16:14 by caroulx
Setting Timing,Idle Icon_minitimeTue 14 Jul - 16:11 by caroulx
Setting Timing,Idle Icon_minitimeThu 2 Oct - 4:18 by Edzuan
Setting Timing,Idle Icon_minitimeMon 22 Sep - 1:49 by kancil 4543
Setting Timing,Idle Icon_minitimeFri 12 Sep - 3:46 by zakiemlk
Setting Timing,Idle Icon_minitimeThu 14 Aug - 16:29 by ferulnbm
Setting Timing,Idle Icon_minitimeThu 14 Aug - 6:48 by genji kuwahara
Setting Timing,Idle Icon_minitimeThu 10 Jul - 16:44 by mesin tebu
 Setting Timing,Idle
3 posters
Setting Timing,Idle Empty
PostSubject: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeThu 1 Apr - 15:29
asalam semua...selalunya utk enjin turbo korang set berapa timing rpm masa idle dan masa pasang aircond?dan kalau tbo besar mcm td04..etc.... slalu krng set berapa rpm masa idle,aircond?
tq Setting Timing,Idle Suspect
http://www.smokerhaven77.com
ForitsCuore
ForitsCuore
Number of posts : 16
Registration date : 14/04/2010
PostSubject: Re: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeFri 16 Apr - 22:19
recommended idle for L2 is 800+/-50 rpm. With air conditioning u no want it go no more than 1000rpm
PostSubject: Re: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeSat 17 Apr - 8:57
forsits:tx fr the info bro.eventhough using bigger turbine,oversized pistons etc...shud be the same settings is it?...
ForitsCuore
ForitsCuore
PostSubject: Re: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeSat 17 Apr - 14:14
Only a drop in compression ratio would affect your idling. Jus try not to make it b idling over 1000rpm...like mine Mad, I thinking it's due to the high timing I cant seem to avoid Mad
What size injectors you using?
PostSubject: Re: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeSun 18 Apr - 8:34
as for nw im running 240cc injcts,1.3b at 40psi adj f.regulator settings...
Registration date : 20/12/2010
PostSubject: Re: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeSun 6 Mar - 15:40
i also need the answer..
ForitsCuore
ForitsCuore
PostSubject: Re: Setting Timing,Idle   Setting Timing,Idle Icon_minitimeMon 7 Mar - 5:17
Setting idle at 900-1000rpm should be could. hate how the car is when it is idling at 800rpm, worse yet the stoff engine mounts Shocked
Setting Timing,Idle
» VIP Table Setting Package "cheap"
