 Check Engine L200/s Indicator Diagnosis
Number of posts : 66
Registration date : 19/09/2007
PostSubject: Check Engine L200/s Indicator Diagnosis   Tue 23 Feb - 7:28
ust wanna share below is a list of the check
engine indicator diagnosis.
blinking - problem
1 -
satisfactory operation
2 - Map
3 - Ignition signal
4 -
coolant temp
5 - oxygen
7 - throttle sensor
8 - intake air
temp
9 - speed
10 - s signal
11 - sw signal
there is
a socket in the engine bay that we have to short it. the socket is on
the left side of the engine bay near the coils. the socket having 4 pin
BUT only 2 pins to be shorted to check if the engine/machine/cars is
clear of problems.
hope could help ...
some pics for guidance ...
below pictures as you can see is the socket that
is to do the checking/shorting but this is not the right way i think
but it does the jobs for me to check what is the problem ....
As for pic below ... the socket is
pulled out .. and you can see the orange female socket inner it .... you
can see also the two terminal with black marker and that is the one to
be shorted.
for procedure to see ...
turn
off ignition.
shorting the socket as above pics.
then turn on
ignition (just turn on no need to start the engine)
then wait for
secs then the check engine will blink ... and you can see from the guide
above ...
View user profile http://compactmotorsports.yoo7.com
CAR
Number of posts : 38
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Tue 23 Feb - 11:32
otai...engine check yg mane satu erk? yg ade tulisan CHECK tu ker?
mirahaw
Number of posts : 194
Birthday : 06/11/1989
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Thu 25 Feb - 1:02
aku rase yg warne kuning tu. lambang pelik2. haha
View user profile http://www.facebook.com/hawmya
KM RACER-X
Super Dragger
Super Dragger
Number of posts : 551
Birthday : 08/07/1982
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Thu 25 Feb - 6:53
betul tu.... warna kuning....
gambar eh lobih kurang mcm gambar enjin....
black
Number of posts : 470
Birthday : 16/07/1971
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Sat 27 Feb - 18:15
kuning ka kan oren...hehehe
View user profile http://www.facebook.com/shahrilazni?ref=profile
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Sat 27 Feb - 20:40
betul betul betul
KM RACER-X
Super Dragger
Super Dragger
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Mon 1 Mar - 6:33
ferulnbm wrote:
betul betul betul
apo yg botul ferul?....
p44autoworks
Number of posts : 34
Birthday : 01/12/1982
Registration date : 14/03/2010
PostSubject: Re: Check Engine L200/s Indicator Diagnosis   Wed 24 Mar - 0:42
x da gambar pun.....
