| 1000t ..? | |
+24consonar skronotoros shafiq111 ervelly navz fakhrul mirahaw aWe89 kancilstnd skupkecik zairul_whx pharin melfice ZiQ nANa zUrA^AniEySzA red_k ferulnbm MAKitam matnoor KM RACER-X Bearz red_october black Admin 28 posters |
Admin Admin
Number of posts : 66 Registration date : 19/09/2007
| Subject: 1000t ..? Tue 23 Feb - 7:26 | |
| Info from flamefox
try to summarize about the conversion for 1000T and compile my knoledge and what abg dude tell me and others
what u need is L2 complete halfcut..gearbox not necessary if u want to use ur current gearbox, and 1000 block.
what's very basic 1000T made of :
1) 1000 block (have to rebore 1.0mm each cylinders if want to use 2E's pistons - 73.0mm) 2) 850 conrod 3) 850 crankshaft ----->> abg dude says this setup is better as 850 crank got oil passage hole 4) 2E pistons or 4E (74mm - can fit or not i dunno) or any piston that fits 5) L2 complete wiring + ECU 6) 2E piston ring, wrist pin and so on ---------------->>>> i'm not sure 7) L2 complete head including cam (plug and play), if u want PnP also can metal gasket (have to cut unnecessary part - mine is like this) *optional 9) L2 extractor, have to make flange if u change to different turbo (*optional) 10) L2 throttle body + intake, can upgrade to bigger TB (*optional) 11) L2 distributor, coil, spark plug and so on, can upgrade to MSD hehe (*optional) 12) SAFC *optional 13) external high capacity fuel pump..better use 1 than 2 in series. but 2 parallel is good...just like coconut hehehe. use L2 stock fuel pump in tank also can i think 14) L2 fuel rail with stock fuel regulator, can use adj. fuel reg also (*optional) 15) stock L2 injectors, no need extra. can use extra or bigger injectors (*optional) 16) stock L2 turbo, (high low rpm torque but die fast and damage fast too), u can use any bigger turbo (*optional) 17) stock L2 top mount intercooler, can use any bigger intercooler and put front mount (*optional) 1 L2/850/660/auto gearbox..or any gearbox that fit 19) oil cooler (*optional) 20) all L2 sensor (important!!) 21) 850 timing belt + tensioner bearing 22) clutch set (if auto no need la kekeke)
what u need to do is :
1) rebore 1.0mm each cylinder on 1000 block 2) drill any sensor hole (knock sensor) on 1000 block (just copy the L2 block) 3) drill hole at 1000 oil sump for turbo return line 4) close the 1000 block's extra hole with copper (tembaga) - abg dude says so 4) fit in 2E piston with ring, wrist pin and so on to 850 conrod that attach to 850 crankshaft 5) fit in L2 head onto 1000 block with metal gasket (optional) in between. dun forget copper spray if put metal gasket 6) fit in all L2 stuff like turbo, intercooler, extractor, intake manifold, TB and so on 7) get ur engine an exhaust set (dumpipe, downpipe, piping and so on) get ur engine an intake set (air filter, intercooler pipe and hoses if needed) 9) fit in ALL L2 sensor including MAP sensor, O2 sensor+exhaust temp sensor (put in ur downpipe), knock sensor (on 1000 block), throttle sensor (at TB) and so on if got 10) fit in all L2 wiring and ECU
i think this is enough to run ur 1000T, becos basically 1000T basic and 850T basic is almost alike. setup is the same.
only if u got extra money then u can change to bigger turbo + intercooler, haltech motec and so on. | |
black Moderator
Number of posts : 470 Birthday : 16/07/1971 Age : 52 Location : Alor Setar,Kedah Registration date : 24/02/2010
red_october
Number of posts : 6 Birthday : 29/10/1977 Age : 46 Location : JAY BEE Registration date : 27/02/2010
| Subject: Re: 1000t ..? Wed 3 Mar - 3:50 | |
Ader gambar tak lubang mana yg nak tutup...... Kang salah tutup, lain lak jadi........huhuhuuhhu | |
| Subject: Re: 1000t ..? Wed 3 Mar - 3:56 | |
KM RACER-X Super Dragger
Number of posts : 551 Birthday : 08/07/1982 Age : 41 Location : Seremban - Senawang Registration date : 24/02/2010
| Subject: Re: 1000t ..? Wed 3 Mar - 4:22 | |
red_october
| Subject: Re: 1000t ..? Thu 4 Mar - 16:21 | |
| Takde saper2 ker yg bole reply msg aku kat atas......????? wwwaaaaaa.................. | |
| Subject: Re: 1000t ..? Thu 4 Mar - 16:40 | |
| ko tiru mcm blok 660t l2 pnya...ko copy kat blok 1000 tu kot... | |
MAKitam Moderator
Number of posts : 474 Location : melaka Registration date : 24/02/2010
| Subject: Re: 1000t ..? Mon 15 Mar - 15:06 | |
| - red_october wrote:
- Takde saper2 ker yg bole reply msg aku kat atas......????? wwwaaaaaa..................
tgok dr atas blok ade lubang besar lbhkurng 10 sen tu.... | |
ferulnbm Moderator
Number of posts : 394 Birthday : 14/11/1983 Age : 40 Location : rawang,n9 Registration date : 23/02/2010
| Subject: Re: 1000t ..? Tue 16 Mar - 1:15 | |
| ha tu kan MAKitam dah reply nice info.... | |
| Subject: Re: 1000t ..? Tue 16 Mar - 1:50 | |
| yup ... ..thanks 4 the info .. | |
zUrA^AniEySzA Active in DRAG
Number of posts : 281 Birthday : 07/10/1985 Age : 38 Location : sErEmbAn-sEri kEmbAngAn-sErEmbAn Registration date : 24/02/2010
| Subject: Re: 1000t ..? Tue 16 Mar - 5:46 | |
| NicE infO brO.... BiLEr LA dEn nAik mAsUk 1000t NiE... hAk hAk hAk.... | |
Number of posts : 50 Registration date : 02/03/2010
| Subject: Re: 1000t ..? Sat 10 Apr - 4:49 | |
| cam best jer 1000T... tp xley rev smpi 10k. hhahahaha... | |
melfice
Number of posts : 30 Birthday : 05/04/1991 Age : 33 Location : Alor Star, Kedah Registration date : 27/04/2010
| Subject: Re: 1000t ..? Thu 13 May - 15:07 | |
| best ka 1000T
| Subject: Re: 1000t ..? Thu 13 May - 15:45 | |
| - ZiQ nANa wrote:
- cam best jer 1000T... tp xley rev smpi 10k. hhahahaha...
perlu kr rev tinggi2 sy newbiz jeee | |
pharin Active in DRAG
Number of posts : 106 Birthday : 15/07/1980 Age : 43 Location : pantai dalamas Registration date : 18/03/2010
| Subject: Re: 1000t ..? Mon 23 Aug - 3:02 | |
| blok sibuu stakat gt25 x cukup...kena sumbat gt28 huk huk huk bak kata ****s | |
zairul_whx
Number of posts : 22 Registration date : 23/05/2010
| Subject: Re: 1000t ..? Mon 23 Aug - 7:32 | |
| org2 lamo..
blok seribu rupiyah ni klau masuk piston 4e ok ker?gasket ngam2 piston aku tengok..takut putus ajer gstring gasket tu,pengalaman user2 piston 4e share2 buleh,goyang pulak aku.. | |
melfice
| Subject: Re: 1000t ..? Mon 23 Aug - 8:32 | |
| nk tgok cmne Gt25 ke GT28. | |
zairul_whx
| Subject: Re: 1000t ..? Thu 26 Aug - 1:52 | |
| - zairul_whx wrote:
- org2 lamo..
blok seribu rupiyah ni klau masuk piston 4e ok ker?gasket ngam2 piston aku tengok..takut putus ajer gstring gasket tu,pengalaman user2 piston 4e share2 buleh,goyang pulak aku.. pandangan2,nak sejukkn hati nie.. | |
black Moderator
| Subject: Re: 1000t ..? Thu 26 Aug - 20:18 | |
| 4e boleh ggti boleh honda pon boleh..... | |
skupkecik Active in DRAG
Number of posts : 32 Registration date : 01/03/2010
| Subject: Re: 1000t ..? Fri 27 Aug - 21:34 | |
| pharin:yeke kne pkai gt28 bru syok?bis yg pkai td05 china made mcm aku ni xde la hrpan nk laju? hmmmm...ke cmner? | |
MAKitam Moderator
| Subject: Re: 1000t ..? Sat 28 Aug - 1:21 | |
| - zairul_whx wrote:
- zairul_whx wrote:
- org2 lamo..
blok seribu rupiyah ni klau masuk piston 4e ok ker?gasket ngam2 piston aku tengok..takut putus ajer gstring gasket tu,pengalaman user2 piston 4e share2 buleh,goyang pulak aku.. pandangan2,nak sejukkn hati nie.. bole masuk piston 4e....gasket xde masalah... | |
zairul_whx
| Subject: Re: 1000t ..? Sat 28 Aug - 3:44 | |
| - MAKitam wrote:
- zairul_whx wrote:
- zairul_whx wrote:
- org2 lamo..
bole masuk piston 4e....gasket xde masalah... thanx dude.. | |
zairul_whx
| Subject: Re: 1000t ..? Sat 28 Aug - 3:51 | |
| - skupkecik wrote:
- pharin:yeke kne pkai gt28 bru syok?bis yg pkai td05 china made mcm aku ni xde la hrpan nk laju? hmmmm...ke cmner?
alamak,why pharin whyyyy.. | |
kancilstnd
Number of posts : 11 Registration date : 21/10/2010
| Subject: Re: 1000t ..? Tue 2 Nov - 14:26 | |
| salm forumerē kalo bsic 1000t ni brapa hp blh dpt ye... block 1000 pisten 2e cnrd 850 crnk shft 850 turbo td04hl pump walbro safc2 gear box L2 lsd yg lain stock l2.. block 1000 ni brape size last bore.. newB | |
aWe89
Number of posts : 90 Registration date : 01/03/2010
| Subject: Re: 1000t ..? Wed 3 Nov - 5:47 | |
| - kancilstnd wrote:
- salm forumerē
newB lau tak silap.. ari tu rasa nya ade org bore utk pakai piston 87 (gen2).. tatau la hasil nye macamana lak.. | |
| Subject: Re: 1000t ..? | |
| 1000t ..? | |
