| TDO4 , RHF , GARRET ETC .. | |
+46raw_board ahmad Albab cross karl_razlie Mr.X blacklist Engky sipanitera KingZ mamat999 toopheq ForitsCuore zairul_whx madi jai alfero hairil jetpa86 fakhrul miziL2s kazirikashi WakJoi consonar akulanie beehun awent77 ZiQ nANa limeston09 voicenoice zUrA^AniEySzA dvvt_T some_soul ferulnbm DausZ CM171 skupkecik matnoor black MAKitam mirahaw bluethunder kai_ree skronotoros KM RACER-X 882T Bearz red_k 50 posters |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Fri 27 Aug - 7:50 | |
| ooo... kene modified rupenye TD04-09 kalau nak muncung ke bwh... selame pakai x tau lak tebo tu dah modified gitu... | |
zairul_whx
Number of posts : 22 Registration date : 23/05/2010
| Subject: Re: TDO4 , RHF , GARRET ETC .. Fri 27 Aug - 9:45 | |
| - fakhrul wrote:
- RHF5 plak,sapa penah pakai..?
dari segi: 1)respon 2)ketahanan etc... red k antara users RHF5,reveal sikit bos..aku pun teringin nak tahu pasal turbo ni,kot2 ada rejeki nak tukar turbo nnt.. | |
ForitsCuore
Number of posts : 16 Location : Jamaica Registration date : 14/04/2010
| Subject: TD04 hybrid Sat 6 Nov - 3:43 | |
| Currently my exhaust housing has a crack which makes no sense repairing. I am getting a deal on a blown TD04L. Can I plug the exhaust housing of the TD04L to me TD04-09?
Also thinking of using the front housing too | |
ForitsCuore
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 2:06 | |
| Could someone share their experience with the GSR td04 on a 660t. What RPM does boost start to build? | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 3:22 | |
| Fortis:I've been running tdo4-09 taken out from a gsr engine nearly 2yrs now,boosting 1.5bar,doesn't dispoint me so far....cheers! | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 5:51 | |
| - awent77 wrote:
- Fortis:I've been running tdo4-09 taken out from a gsr engine nearly 2yrs now,boosting 1.5bar,doesn't dispoint me so far....cheers!
me too... | |
toopheq Active in Uphill Racing
Number of posts : 95 Birthday : 06/07/1992 Age : 31 Location : Subang Jaya,USJ Registration date : 10/11/2010
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 9:43 | |
| Yes kairee lama tk dgr cite...haha!amcm kete bro semakin laju mengunakan turbine gsr kah?tlg mmbr fortis bgi idea skit... | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 9:52 | |
| Toopheq: ikut spec engine kau jgk bro,...alang2 nk masuk tbo besar cari buntot yg ngam la ikut citarasa engine kau tu....boleh refer formula mmbr2 forum yg pernah try n error... | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 12:14 | |
| spec kete,internal semua stended, cuma buat downpipe je,so tk nk bazir duit nk buat downpipe baru,ingat nk pakai balik flange sama, | |
mamat999 Dragger
Number of posts : 192 Birthday : 22/07/1984 Age : 39 Location : terengganu Registration date : 19/04/2010
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 15:43 | |
| - toopheq wrote:
- spec kete,internal semua stended, cuma buat downpipe je,so tk nk bazir duit nk buat downpipe baru,ingat nk pakai balik flange sama,
cari la yg da siap kacuk. kt tong da siap kacuk pon ada | |
ForitsCuore
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 16:52 | |
| Thanks awent77. I thought the grs turbo was called TD04-13G tho, the 09 come from the Pajero and L200. I am wearing an 09 now,but my turbine housing is giving me problems. I welded it, jus want to know what I could move to jus in case. We have a lot of TD04 from Mitsu Evo and Subaru here, jus wondering how much more laggy they are compared to 09 | |
mamat999 Dragger
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 17:00 | |
| - ForitsCuore wrote:
- Thanks awent77. I thought the grs turbo was called TD04-13G tho, the 09 come from the Pajero and L200. I am wearing an 09 now,but my turbine housing is giving me problems. I welded it, jus want to know what I could move to jus in case. We have a lot of TD04 from Mitsu Evo and Subaru here, jus wondering how much more laggy they are compared to 09
i think not so much laggy, just a little. td-04 vs td04-09. just a little diffrent | |
ForitsCuore
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 17:02 | |
| Much appreciated bros. Right now my turbo gaskets are leaking. Thinking of using a sheet of copper. Any other suggestions? | |
mamat999 Dragger
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 17:11 | |
| why don't just use self made exhaust gasket | |
ForitsCuore
| Subject: Re: TDO4 , RHF , GARRET ETC .. Sat 27 Nov - 17:33 | |
| What material would you suggest I use. Tried asbestos blew out with the first pull [POWER!!!! ] I was thinking of using copper. What's the suggested thickness? | |
mamat999 Dragger
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 3:56 | |
td04-09 come from pajero diesel and wira diesel, not too laggy for internal standard (68mm pistons).. if u are still using stock internal pistons (68mm) and u dont wanna use td04-09, i suggest u to use rhf4 hybrid wif l2.. if u wanna try td04 from GSR or SUBARU and not hybrid wif 09, i think wif internal standard, it will laggy like hell.. | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 8:07 | |
| another turbo like rhf4 vf14 and vf13 also laggy with internal standard? (Piston 68mm) | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 8:48 | |
| so like my car is internal all standard, but i want to upgrade to a bigger turbo, any turbo that you guys can suggest? | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 11:18 | |
| - toopheq wrote:
- so like my car is internal all standard, but i want to upgrade to a bigger turbo, any turbo that you guys can suggest?
usually standard internal people may choose for td04 09 bcoz of not too laggy n a bit lasak..other turbo is from rhf4 series..these turbo also well known n easy to get.. just my 2cent from newbie.. | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 12:20 | |
| fakhrul, ni aku lah taufiq, heheeh saje speaking.. | |
mamat999 Dragger
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 16:11 | |
rhf4vf20 hybrid l2. | |
ForitsCuore
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 22:24 | |
| I have a very nice TD025 at home notbin to do with it. gonna polish it and put it on my dresser I am using 2E NA pistons [73mm], jus got another TD04-09, I have noted that there are different TD04-09 about the place, the one I got today seems to have smaller backwheel. Will do measurements and take pics later this week | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. Mon 29 Nov - 22:28 | |
| - toopheq wrote:
- fakhrul, ni aku lah taufiq,
heheeh saje speaking.. haha i know, just to share with fortiscoure.. sorry for the broken english go for td04-09 la brader, u already feel it.. otherwise u use rhf4 like bro mamat said.. but have to hybrid la.. | |
| Subject: Re: TDO4 , RHF , GARRET ETC .. | |
