| kete payah nak start... | |
+5mamat999 skronotoros CAR akulanie kai_ree 9 posters |
| Subject: kete payah nak start... Wed 12 May - 17:31 | |
| kete aku belalang enjin L2S, Fuel pump Evo, FR Mines & SAFC 1... bile sejuk senang je nak start... tapi bile dah jln pastu berenti... lepas 1/2 jam gitu payah nak start... apsal yek??? nak kene tekan2 pedal minyak baru leh start... pening dah aku... | |
akulanie COMPACT Mechanic
Number of posts : 54 Birthday : 07/08/1977 Age : 46 Location : Ampang-Jln Ipoh Registration date : 24/02/2010
| Subject: Re: kete payah nak start... Thu 13 May - 19:54 | |
| hah!...abis... | |
CAR Active in DRAG
Number of posts : 38 Location : Sunway Registration date : 23/02/2010
| Subject: hahaha Fri 14 May - 1:50 | |
| hahah ni la kes kete aku dr dulu sampai skrg... kalau dah panas 30min++ baru bleh start balik hehehe... ade org ckp sbb aku letak bateri kat blakang dan bateri kecik N60(dah besar da nie)..puaskan hati org tukar p N70..same gak wakakaka... ade lak kata sbb kabel bateri tu besar sgt 400mm..setau aku lg besar lg bagus la... tp bertahun2 perhatian aku takde masalahnyer mungkin..starter atau pun bila kita on kunci injector akan sembur skit kat dlm kebuk pembakaran tu...memandangkan dah pakai injector besar dan pump super power plug basah bila on kunci... tp tak tau le betul ke tak teori aku...aku pun masih baru lg dlm modified2 kete ni...tak tau ape2 pun lg... | |
| Subject: Re: kete payah nak start... Fri 14 May - 3:14 | |
| aku dlu pn kes mcm ko.. ssh nk start ble pns.. sume da wat cm abam din ckp kecuali tuka bateri.. so,last solution aku pasang relay starter.. alhamdulillah..smpai skg ok.. relay starter aku bli kt pndan indah siap wayar = rm15.. | |
CAR Active in DRAG
| Subject: Re: kete payah nak start... Fri 14 May - 3:38 | |
| - skronotoros wrote:
- aku dlu pn kes mcm ko..
ssh nk start ble pns.. sume da wat cm abam din ckp kecuali tuka bateri.. so,last solution aku pasang relay starter.. alhamdulillah..smpai skg ok.. relay starter aku bli kt pndan indah siap wayar = rm15.. otai toros...relay starter tu tuk ape? mcm mane bentuk dia..ade ke same mcm relay biasa tu atau lain? ape guna dan fungsi dia? terangkan la... sori la ye byk tanye...maklumlah newbie.. | |
| Subject: Re: kete payah nak start... Fri 14 May - 5:08 | |
sori la ye byk tanye...maklumlah newbie.. hahahahaha..poyo tol abam din nih.. relay nih fungsi die utk menghubungkan + memutuskan aliran elektrik.. kre switch la..arus yg lalu direct dr bateri.. dlm tuh ade la coil die ape sume.. mengikut ape yg aku taw la..kalo slh tlg btolkn.. relay starter nih ade 1 jenis je.. sume kete leh pkai.. | |
mamat999 Dragger
Number of posts : 192 Birthday : 22/07/1984 Age : 39 Location : terengganu Registration date : 19/04/2010
| Subject: Re: kete payah nak start... Fri 14 May - 6:39 | |
| aku dulu pn penah kena camni. pas servis starter ngan tambah relay trus ok.
p/s : relay tu untuk tambah arus bagi kuat sket. so laju la sket starter pusing | |
| Subject: Re: kete payah nak start... Sun 16 May - 17:19 | |
| ade org kate temperature sensor dekat blok tu yg kong... masalahnye skang ni kalau pasang ekon lagi la gile pulak kete aku... nak mati pun ade mcm minyak x masuk... sebelum pasang SAFC 1 ni xde lak gitu... kalau betul temperature sensor tu mane nak carik bende alah tu??? | |
dvvt_T Active in Circuit Racing
Number of posts : 114 Registration date : 24/02/2010
| Subject: Re: kete payah nak start... Sun 16 May - 20:30 | |
| Subject: Re: kete payah nak start... Mon 17 May - 16:02 | |
| senang nak dpt ke bende tu??? mane nak dpt yek??? sape ade??? tapi bile minyak set lebih kat low rpm die senang lak start... skang set +5% kat 1000 rpm +1 kat 2000 rpm... tapi kalau head kotor jadik gitu gak ke??? aku punye carbon yg kat ekzos tu punye la byk kalau aku start kete... naik hitam lantai umah... | |
bluethunder Active in DRAG
Number of posts : 52 Birthday : 09/04/1978 Age : 46 Location : pahang-n9-subang jaya... Registration date : 02/03/2010
| Subject: Re: kete payah nak start... Mon 17 May - 19:52 | |
| - kai_ree wrote:
- kete aku belalang enjin L2S, Fuel pump Evo, FR Mines & SAFC 1... bile sejuk senang je nak start... tapi bile dah jln pastu berenti... lepas 1/2 jam gitu payah nak start... apsal yek??? nak kene tekan2 pedal minyak baru leh start... pening dah aku...
try wide band dulu keto tu...minyak x ngam.... | |
| Subject: Re: kete payah nak start... Thu 20 May - 15:51 | |
| jenuh nak dah wideband... Ann kate nak try tukar ECU... camni nak kene tanye Wan ade sensor2 tu x kat blok sape2 yg dah upgrade... sape ade sensor tu leh jual kat aku??? | |
BroSA
Number of posts : 26 Registration date : 23/06/2010
| Subject: Re: kete payah nak start... Mon 5 Jul - 3:31 | |
| lebih kurang sama kes dgn keta aku gaklah. antar gi pomen wireman dia kikis wayar body ke engine dah tu ok pulak. kata pomen body keta contack x cantik. | |
| Subject: Re: kete payah nak start... Mon 5 Jul - 16:47 | |
| lupe lak nak update... skang lepas aku d'carbo... ok la pulak... xde masalah... pastu tambah wayar dr depan ke bateri blkg... senang gile nak start... lampu pun cerah bagus... | |
2bMIRA
Number of posts : 8 Location : pahang Registration date : 08/02/2011
| Subject: Re: kete payah nak start... Tue 8 Feb - 6:04 | |
aku nye plak....pepagi tak leh stat...kena tekan minyak baru hidup...pastu....lama sikit bila sejuk...kena tekan minyak baru stat....apa kes???? | |
| Subject: Re: kete payah nak start... | |
